ir Advance 6265
  • imran181070
    • Aug 2016
    • 24
    [Dead] ir Advance 6265
    only pilot green light and Standby light is ON at startup no any movement
    help is required
    regards
    Re: ir Advance 6265
    help is required regards
    well can't see anything in pic due to GLARE.
    have you gone in and disabled POWER SETTINGS for sleep mode?
    how long has this been going on?
    did you have a power surge or lightening strike?
    you must be an end user
    • imran181070
      • Aug 2016
      • 24
      Re: ir Advance 6265
      no sir i m not END USER machine was working till end of day
      next morning when ON the machine ,since then only pilot green light & standby light is
      always ON ,customer has no knowledge about user setting even not interested ,yesterday found
      may be ALL NIGHT power supply to replace.
      • roho
        • Mar 2009
        • 844
        Re: ir Advance 6265
        There is no one fix for this, could be a few things. Could be any of the power supplies, or controller boards. You will need a multi meter and start checking for power. Start at the power supplies, after confirming you are getting AC power in, start looking for DC voltages. Chances are you will find at somepoint that the DC voltage is missing somewhere along the chain.
        Had a couple of these, both times a different board, but was able to narrow it down this way.
        • smiley
          • Aug 2008
          • 615
          Re: ir Advance 6265
          help is required
          regards
          i have been on this before. The machine arrive on our shop with only pilot lamp is on. We replace the whole power supply and dc con with no luck and also the control panel. But i replace the ip main 1 that solve the problem you can try to realigned the connection betweet ip main 1 and ip main 2.
          there is no glory without sacrifice
          • roho
            • Mar 2009
            • 844
            Re: ir Advance 6265
            Main controllers a among the most expensive parts and may or may not be the problem. Sometimes it is one of the power supplies as in my case. I recommend using a meter and voltage checks to attempt to isolate the problem, hoping to avoid the extra cost and down time just throwing parts at it. Checking voltages would confirm if the power supplies are fine, leading to a quicker diagnosis of the controller if that is the case.
            Could be any of the power supplies, controllers etc. If you don't isolate the issue then you will be just throwing parts at it.
            • imran181070
              • Aug 2016
              • 24
              Re: ir Advance 6265
              atl last i fixed the problem by only re seating main controller 1 & 2
              AH
              regards
