Canon C5051 Image runner Wavy paper
  • Arcadian
    • Feb 2010
    • 218
    I have a C5051 Unit just change Fuser and getting waving paper, coming out i changed the fusing temp. in tech mode, but once in a while, im still getting wavy paper, see picture.
    think it might be transfer roller??
    changed fuser and ITB assembly.
    any advice??
    Thank for reading.
  • guitar9199
    • Sep 2016
    • 1099
    Re: Canon C5051 Image runner Wavy paper
    [ATTACH=CONFIG]43493[/ATTACH]
    any advice??
    Thank for reading.
    Try some fresh paper. Anytime I ever get waves like that, it's usually due to damp paper.
    • Arcadian
      • Feb 2010
      • 218
      yeah i tried that with new reams and even new box of ream.
      same thing.
      the xerox in the same room doesnt do this, and its right next to it, using the same paper.
      • mc007
        reliable tech
        • Jan 2019
        • 28
        any advice??
        Thank for reading.
        make sure fixing unit is good one ,check registration flag is actuating properly and there is any obstacles in paper transport path especially near the pre transfer roller
        you can also check with adjusting the paper gsm ,try 80-100 gsm
        • techandtrader
          • Jun 2016
          • 318
          Looks like the small narrow roller on the fuser is gummed up. Its the Orange one that flips out with the cover. If it doesn't roll easy then there is your delay. I keep those bushings lubed. When older imagerunners do this it was fuser or old delivery rollers creating a delay.
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • Arcadian
            • Feb 2010
            • 218
            this is the thing, we bought another fuser twice from different vendors and still comes out wavy, i turned down the temp on the fuser for bond paper seems to work for a while, then after about say 200 copies it started to do it again, Im leaning toward the paper but ill look at your suggestion, because its was a new fuser these are all refurbished, Thanks for the tip. though Awesome EYE!!!
