Canon IPF 825 image problem
  • EvilHamster
    • Jul 2019
    • 7
    [Misc] Canon IPF 825 image problem
    Canon IPF 825
    Problem with image quality.
    Breaks the lines along the length of the sheet.
    Clean heads A and B. Change printhead.
    Whether I need to change the carriage unit with belt?
    What can i do to check what unit gave me that problem?
  • guitar9199
    • Sep 2016
    • 1100
    Re: Canon IPF 825 image problem
    That looks more like an encoder sensor issue. Clean your encoder strip and see if that doesn't take care of it. You might also want to make sure the carriage shaft is clean. No grease on it either.
    Good luck.
    • EvilHamster
      • Jul 2019
      • 7
      Good luck.
      Thank you for reply. It doesn't help. Cleaned shaft and encoder. Add one more image with this problem.
      • Copylady72
        • Jul 2019
        • 35
        Have you tried sliding the carriage back and forth on the shaft just with your hand while the machine is off to make sure it is sliding smoothly? Make sure the encoder strip and belt are not binding up while moving. If it is moving smoothly, it could just be the encoder unit that is mounted on the back of the carriage.
        Sent from my SM-N950U using Tapatalk
        • EvilHamster
          • Jul 2019
          • 7
          Everything looked, the carriage slides smoothly, the encoder cleaned. All settings produced.
            • 23003
            Ok, so the encoder strip is clean. Does it have any scars or spots of ink?The encoder strip is piece of plastic with very thin silk screened lines printed along the whole length of it. If any of those marks are worn, scrubbed off with cleaner, or coated with oil or ink, the carriage won't move smoothly. And if the carriage bushings are binding, the carriage won't move smoothly. Look closer. =^..^=
            • Canuck
              Tech Specialist
              • 1713
              You followed proper procedure for head replacement? Didn't just stick it in without it doing auto head adjustment, nozzle check,etc? Gotta check the basics first. Firmware upgraded also? And regardless what Canon says, I oil the carriage rail with sewing machine oil after cleaning it. I've been working on Canon wide-format for 20 years and seen then grind and give carriage errors when dry. Post a service mode nozzle check...
              • V-P
                • Apr 2011
                • 679
                I would follow Canuck advise.
                Also there is an "Adjustment Section" in the menu.
                Try having a look at the "Angle Height Adjustment"
                • EvilHamster
                  • Jul 2019
                  • 7
                  Thank you all for your advice. All standard procedures were carried out. Firmware updated to the latest on the site. Adjustment of the height of the angle produced. A little later I'll grease the carriage rail.
                    • 23003
                    Use small amounts of EU-1. It's called grease but it's really an oil. Using the correct lubricant is important in this situation:
                    • EvilHamster
                      • Jul 2019
                      • 7
                      [ATTACH=CONFIG]43786[/ATTACH]
                      Lubricated shaft, no changes occurred. Talked to users, said that the problem appeared after the last repair.
