canon C1 DEV units
  • SCREWTAPE
    • Aug 2025
    #16
    Here is a break down of the procedure.
    As soon as the screen is displayed on the control panel, select the following Service Mode:
    COPIER > FUNCTION > INSTALL > AINR-OFF; then, enter '1' and press the OK key.
    Y Developing Assembly: COPIER > FUNCTION > INSTALL > INISET-Y
    M Developing Assembly: COPIER > FUNCTION > INSTALL > INISET-M
    C Developing Assembly: COPIER > FUNCTION > INSTALL > INISET-C
    Bk Developing Assembly: COPIER > FUNCTION > INSTALL > INISET-K
    'OK!'
    is displayed on the screen after completion of this mode.
    You can also do iniset 4.
    Execute the following service mode: COPIER > FUNCTION > MISC-P > P-PRINT; then, store the
    output papers. If there is any previous P-PRINT output, replace it with the new one.
    Exit Service Mode, and select User Mode > Auto Gradation Correction. Execute Auto Gradation
    Correction (full adjust) according to the instruction on the display.
    • worthy
      • 9
      #17
      Thankyou for the info . The procedure in my service manual isnt the best , Think im on an early revision .Did the course about 2 years ago then nearly a year before i got to see one . got a few out there now , a couple of the machines definatley sold in wrong environment . Sold into printers doing lots of full bleed solid colours heavy card stock all day long ! Our salesmen are great .....not .
      Anyway Thankyou again for your help and reading my moaning rant .
      • Penvy
        • Oct 2008
        • 237
        #18
        I would like to know where you can get just the DEV or starter
        Thats the MAIN problem
        The DEV units are fine just the DEV has run out
        and you will never get a good ratio on the dev service code.
        Then the ATR just goes nutz......its really working like it should
        but cuz the developer/toner ratio is bad
        well thats just what happens and
        YOU ARE RIGHT only 75-80K before they all go bad
        BUT the K will be ok cuz its not reading the K in color.
        Well what do you know, after all
        I am NOT crazy
        Screwtape nailed it on the head.
        Where can you get JUST the starter for these dev units .
        I know how to do the rest.
        I still get no answer from canon.
