I want canon Ir adv 4225 firmware
  • Ammu
    • Sep 2019
    • 6
    Want Ir adv 4225 firmware. Any one have pls!
    My mail ycantmarketing@gmail.com
  • guitar9199
    • Sep 2016
    • 1100
    Re: I want canon Ir adv 4225 firmware
    If you have it connected to a network, you can download the firmware directly in Service Mode.
    • Ammu
      • Sep 2019
      • 6
      How to download directly in network please help me...
      • guitar9199
        • Sep 2016
        • 1100
        If the copier is connected to a network and powered up, just go into Service Mode and you'll see the option to "Update Firmware" right on the main screen. Once you press that, just select the most recent version from the list and you can update it from there.
        The whole process is outlined in your service manual.
        • Ammu
          • Sep 2019
          • 6
          I have a doubt, machine now in error condition e602 does it work now
          • guitar9199
            • Sep 2016
            • 1100
            Error 602 is a hard drive error. You're going to need to download Service Support Tool and the iR Adv4225 firmware from the Canon eSupport website. Install Support Tool on a laptop computer, register the 4225 firmware in SST, then connect the laptop with a crossover cable to the copier and use THAT to install your firmware.
            • copier tech
              • 8164
              Did you have this error before or after you attempted to update the SSW?
              • Ammu
                • Sep 2019
                • 6
                Not update
                Sent from my 2014818 using Tapatalk
                  Not update
                  you don't seem to give FULL info at anytime...
                  Are you a certified tech?
                  do you have the service manual?
                  • Ammu
                    • Sep 2019
                    • 6
                    Thank you for all, I'll sort out this issue after replacing sata communication cable...
                    Simply solve that issue.
