C5051 Copy Calibration needed
  • techandtrader
    • Jun 2016
    • 335
    I have a box that seems to require frequent copy full adjusts. How often are you needing to do this on moderate to heavy color use boxs?
    I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
  • teckat
    • 16083
    Re: C5051 Copy Calibration needed
    Heavy use= Once a Day
    Calibrate the Printer
    Calibrate the Rip\Fiery
    It's all about % of color coverage on paper.
    • Canuck
      Tech Specialist
      • 1713
      Make sure the patch reader is clean. If it's dirty, when machine does "quick adjustments" on it's own, the patches on itb will be read incorrectly and it will throw the colors off. Clean it, clean the optics, do CCD adj, white levels, etc. Now do full adjust on all media. make a print, then force the machine to do a quick adjust, and make another print. The prints should be similar and the machine will maintain better color. But if very picky and using heavy..yes, possibly daily or at least before any large run
