IR5570 with T1 Jamming on Legal ONLY
  • Dalamar
    • Oct 2006
    • 117
    Well i guess the title gives the gist of it.
    It will pass maybe 3 or 4 pages of legal then jam, either single copies or multiple.
    The machine will run LTR, LTRR, and 11 x 17 just fine, however legal jams at PS35 and PS36 with 0210 (stationary jam fuser exit sensor) it stops with the paper bunched at the entrance roller in the finisher.
    so far I have:
    Replaced tires in the legal tray
    Tried running legal through the bypas
    switched to face up delivery
    cleared dcon
    replaced finisher control board (luckily i had a spare)
    replaced entrance roller in finisher
    made certain the finisher was level
    I am at a loss.
    pics related.
    Notatechie - "I am trying, but I don't know how to go into Service Mode. If I just go in and press *then 2, than 8, then * it does not do anything."
    SCREWTAPE - "Try harder.."
  • Dalamar
    • Oct 2006
    • 117
    i forgot this little tid bit
    When i detach the finisher it passes legal with no problems.
    • 20YRSEXP
      • Oct 2008
      • 281
      Sounds similar to a problem we had. It may be the wrong finisher, I would confirm the finisher is the one you want by checking the serial number. It would only jam on legal due to a timing issue, but the finishers were almost identical physically.
      Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
      • 20YRSEXP
        • Oct 2008
        • 281
        I think it was an AD1 which goes on the 5055 and looks the same at first sight. the Serial number for the AD1 should start with a prefix of MBN. If it does I think you will need to change the finisher.
        • Dalamar
          • Oct 2006
          • 117
          yes it is the right finisher and the board had the right part number too.
          • smiley
            • Aug 2008
            • 615
            ive seen ths problem in some 5000 series have you to change its model size to 3 so that both ab and inches size will be detect.and try to remove a white roller in the exit unit.
            there is no glory without sacrifice
