send to folder problem
  • mramlawi
    • Jul 2011
    • 838
    was working normally iradv c5255 send to folder using win7 and after my costumer upgrade his won to win 10 the problem happend, and unable to see the work group said no response. tried through url and same problem unable to send. i searched on google tried many steps same problem, should i update the machine firmware or what.
    Distinguished road makes you jewel in rough
    Re: send to folder problem
    SMB1 scanning was removed due to malware threats.
    you will have to get the SMB2/3 firmware from Canon.
    • mramlawi
      • Jul 2011
      • 838
      can i update the firmware through internet
      • mc007
        reliable tech
        • Jan 2019
        • 28
        turn on the smb 1 and make sure network discovery and file sharing its on
        special firmware is available on this model for supporting smb2/3 and its not get from internet
          • 8202
          Turn SMB v1 back on this was disabled in some Win 10 upgrades.
          If scan then works explain to your customer the security risks associated with SMB v1 if they're concerned install the special SMB v2/3 firmware & trun SMB v1 off again.
            Sure enable SMB1. And when your customer gets hit with malware or ransom ware, your boss will be in a law suit.... you could be fired.... and your customer (if infected with ransomware) can lose ALL data or pay high $$$ ransom to get their data back.
            It's techs like you that give us all a bad name.
            SMB1 was disabled by Microsoft. and EVERY MS update will turn SMB1 BACK OFF!
            dumb suggestion!
            • mc007
              reliable tech
              • Jan 2019
              • 28
              dumb suggestion!
                • 30483
                mr Philip agreed , but if the customer requires scan to folder and machine doesn’t support smb2/3 (if the smb2/3 supporting firmware also not available like ir adv c5051 models) . What you will do ?
                In this forum almost every post we can see your comments but only big talks , no solutions so before blaming others you should think what you are !!
                Use ftp to scan via filezillaserver
                Scanning with FTP_FileZilla.pdf
                You must also allow filezilla through windows firewall
                • tsbservice
                  Field tech
                  • 8053
                  mc007, you clearly are not a tech or reliable one, if you know what I mean.
                  There are many ways to resolve customers request and most dumb(yes I agree with Phil) is one you suggested.
                  • mc007
                    reliable tech
                    • Jan 2019
                    • 28
                    • mc007
                      reliable tech
                      • Jan 2019
                      • 28
                      [ATTACH]43581[/ATTACH]
                        I am a servuce manager... have been for decades.. in fact i could have been doing this shit when you were still sucking moms tit!
                        And you are WRONG I only give replies like that to DUMBASSES, hence the reason you got one.
                        Back under the porch puppy!
                          • 30483
                          You just proved his point. Like ALL tech's or Service Managers there are GOOD One's and BAD One's. No real reason to belittle a tech.
                          • mc007
                            reliable tech
                            • Jan 2019
                            • 28
                            really? who cares you are a service manager or not!!!!!!!!!!! till now you cannot provide helpful informations or solutions in any of the threads in this forum (especially in canon copiers threads) only bla bla talks always and your self saying im a manager if you are ,really a useless and shameless manger!!
                            the only thing you are doing here teasing and blaming others nothing else.im not perfect but you are not enough to judge me!
                            i dont want to argue with you more ,have a nice time!!!!!!!!!!!!!!!!!!!
                              • 8202
                              dumb suggestion!
