gp 200 e803
  • pearlpdy
    • 44
    gp 200 e803
    at gp 200 e803 error occur, i check dc board, which electronic component fault that dc board, i replace the dc board new one its work fine, but that faulty board what component we can change plz help me,
  • Peter Sim
    • Sep 2008
    • 445
    E-803
    i don't think is Dc board faulty. If occur againt try to do the setting first under service mode<Function12<R&D SHANDING.Pls follow the procedure. Or check the both ends or the fluorescent lamp has blackened or not. If still cannot,then change composite power supply
    • BLITZKREAGG
      GP 200
      Title : E803, lamp ends black. Error :
      E803 code with both flourescent lamp ends black. Lamp settings were checked and correct. Lamp and composite power supply were changed.
      Workaround :
      Check the lamp cables, found one area where the wire was cracked open and shorting to the frame. Changed cable.
