Hello,,
Have a IR-9070 with this strange cq problem..
First 2 prints come out with little background and 3 lines running on sides (these lines are somehow offset from the 3 stripper fingers under the drum)..all following prints are dark back ground and double image on prints, problem is when printing and copies as well.
Work done sofar: Replaced all the coronas, replaced the dev housing, swapped the whole drum assembly from another machine, reseat all connectors on HV Board, checked all values on copier > adjust all are ok
Note: if pot control turned off..all prints come out blank!
Anny help or ideas appreciated.
