too long transfer the toner into the developer box
  • Nikola Karamanov
    • Apr 2016
    • 58
    Hello! I have a Canon IR 1730i copier, when I put a new compatible toner for one hour it transfers the toner into the developer box, it takes too long to transfer the toner into the developer box. It is heard that it is transferring toner but it is getting very slow.Then after working a little, it starts the same way again.
  • JParker
    Technician II
    • Jul 2015
    • 51
    Re: too long transfer the toner into the developer box
    Do you have any other symptoms? Light copies, etc?
    • Nikola Karamanov
      • Apr 2016
      • 58
      Hello! No, it's just trying to transfer toner from the toner cartridge to developer box, but it's getting very slow, about one hour. No errors, no light copies.
      • tsbservice
        Field tech
        • 7910
        Maybe it's time to change old developer and run calibration. How about original toner if possible?
          yup... 3rd party toner will kill most dev units very quickly....
          when are people going to realize: yes you save on the cost of toner...
          but you'll be throwing good money after bad with all the parts you'll have to replace due to the shitty toner!
          look at all the PQ/CQ issues... 8 out of 10 times it's due to the CHEEP TONER!
          • Nikola Karamanov
            • Apr 2016
            • 58
            This machine work only with compatible toner cartridge! An original toner cartridge has never been put. If I try with original toner ?
              genuine toner
              change to genuine dev powder (clean unit properly per manual)
              run ALL the init/cali procedure IN THE PROPER order
              then get back to us
              • Nikola Karamanov
                • Apr 2016
                • 58
                The problem was gone with new original toner cartridge! Thanks of all!
                • copier tech
                  • 8100
                  A lesson learnt there!
