clc-1100
  • T911
    • Jun 2007
    • 628
    clc-1100
    have a 020-0181 code popping up on this one. should i just stir it or replace the yellow developer and do an install. or should i be looking at dirty sensors. thanks t
  • SCREWTAPE
    • Jun 2025
    I would do a developing change plus clean sensors.
    But try the stir first, just have a bottle of starter with you just in case.
    Also check your density reference levels.
    • djzolla
      • 71
      Hi mate,
      Firstly that code points to magenta not yellow. usually with that code its because the atr sensor gets dirty/soiled. how old are the devs and drum? check what colour is soiling the atr, that will be the colour in question that has the issue. devs on these machines last between 40 - 60 k. do not push em past that. devs stirs do nothing on these machines. 9 times out of ten its cause the devs are old.
      Let me know....
      • T911
        • Jun 2007
        • 628
        thnaks guys ill do a dev change and cleaning.
        • SCREWTAPE
          • Jun 2025
          Whoa
          dj zilla,
          Though you are correct about the ATR sensor being soil buy any color, Y.M.C.K, especially when toner starts to spread inside of the machine because bad or weak starter. In my TRG (manual).
          The order is for the subcode.
          Y. 01xx
          M. 02xx
          C. 03xx
          K. 04xx
          The E20-0181 refers to the color yellow (01) and the (81) refer to the ATR sensor being soiled or faulty. This has been the order for all canon color models from CLC's to IRC's.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Originally posted by SCREWTAPE
            dj zilla,
            Y. 01xx
            M. 02xx
            C. 03xx
            K. 04xx
            You're right.
            On all Canon colour machines the subcode of E020-E025 errors begin with the colour at fault.
