IR5180
  • xtremejr
    • Jul 2025
    IR5180
    I have a IR5480 with a W2 finisher. It is skewing once is a while, when stapleing. any ideas?
  • 11x17
    • Apr 2007
    • 153
    Canon has released ver 7.01 for finisher that allows you to adjust swing assy pressure.
    Please see tech pub if you are a cert tech. If not then call one
    • SCREWTAPE
      • Jul 2025
      xtremejr,
      How ya doing? This had been a problem with b&w and color copiers for a while. Canon has issue updated firmware for W1, W2 PCB controller v7.01, older version is v5.01. If you want i can email the file to you. Check out the techpub it shows the procedure. You do need the PCB downloader tool.
      Screwtape
      • xtremejr
        Thank you
        Thank you for your help
        • Canuck
          Tech Specialist
          • 1713
          File swing guide home position sensor bracket so that it can be lowered about 2 mm...doing this before new software....swing guide comes down farther after this
