How ya doing? This had been a problem with b&w and color copiers for a while. Canon has issue updated firmware for W1, W2 PCB controller v7.01, older version is v5.01. If you want i can email the file to you. Check out the techpub it shows the procedure. You do need the PCB downloader tool.
File swing guide home position sensor bracket so that it can be lowered about 2 mm...doing this before new software....swing guide comes down farther after this
