iR2800
  • copicatt
    • Nov 2008
    • 366
    iR2800
    Did a service call a few weeks ago for poor fusing and E-001 codes. I replaced the entire fuser assembly. I was out there due to another problem today and the customer said that there was still poor fusing at times. They said they tried to run the bulletins on 20# to see if that would help, but they say it didn't help.They only notice this on legal size 2 sided, but then that's really all they run. I couldn't duplicate the problem myself. The machine was moved to a different location in the building a couple months ago. Wandering if power affects these machines as it did the iR210 series (No codes and poor fusing).
  • maks
    • May 2008
    • 75
    ir 2800
    maybe the the power outlet is the problem since the are fusing assembly for 110 and 220 V..
      • 22930
      Oh yes! These machines are subject to power issues. I would get the power quality analyzer out there right away. =^..^=
      • kuby
        • Oct 2007
        • 1373
        Put a surge protector on one that another company was working on and having this issue every month. Customer ask if I could come by and look at it (frustrated with dealer). Have not been back since for the same problem. Now be have a very big account.
        • copicatt
          • Nov 2008
          • 366
          Alright, guys, I did talk to the customer again and she is using generic toner. Not for sure what kind. I use Katun alot and don't have problems, but who know what she's using. Anyway, she evidently is only having this problem on legal, not letter. She runs 70# legal through the bypass, and after wandering if it's a paper problem, they backed down to 60# paper with no luck. I am having her to do a run on 20 # legal to see if she has the problem. If it runs 20# ok, but not 60, what options do I have? Any setting changes? She is selecting "heavy" when using bypass. Thanks!
          • AV8R
            Lurker
            • May 2008
            • 12
            Just checked the specs page for that model - Acceptable paper weight through the bypass is 17-32# bond, drawers: 17-20# bond.
            I'd say that 60# bond is a little out of spec, and would explain poor fusing no matter what brand of toner they're using.
              • 22930
              Amen! =^..^=
