Ipf 770 with L36 has lines when printing
  • nathicana
    • Aug 2008
    • 328
    This IPF 770 has crossfeed lines when printing from a computer on the network.
    Files from the same computer with the same driver recently printed ok.
    The machine is in our showroom. I print to it regularly just to test it.
    I attached an example of the lines and a service mode nozzle check pattern.
    I don't have much experience on these. I appreciate any guidance.
    Re: Ipf 770 with L36 has lines when printing
    ok since nozzle check looks good.
    what SPEED and QUALITY are you printing at?
    epson T series would show similar symps.. if printed at high speed .. low Quality
      • 22960
      You might start with a printhead clean and alignment.
      • nathicana
        • Aug 2008
        • 328
        I ran printhead cleaning A and it cleared up, thanks.
        Before that I ran nozzle check again, from system menu this time and it showed some bad areas.
        212m2 total print area on this machine.
          • 22960
          Its probably just insufficient usage. Ink based machines love to run ... and hate to sit idle. =^..^=
          • linhaplotter
            • Jul 2020
            • 2
            Sorry for posting here, but i have a similar problem. When i print in low quality (Standart 600 dpi or below) the printer do this white lines, they don't occour when i'm printing cad lines in black and white nor do when the print quality is set to high. I've run printhead check (didn't change the print problem) and nozzle pattern check (seems pretty aligned and with no failures).
            WhatsApp Image 2020-07-15 at 10.34.08.jpgWhatsApp Image 2020-07-15 at 10.33.40.jpg
              • 22960
              Sorry, I can't get anything from your attachments. Can you try another way? =^..^=
              • linhaplotter
                • Jul 2020
                • 2
                Sorry, i did not notice the bad quality of the uploaded image.
                IPF770 white lines.pdf
                  • 22960
                  You may have ink buildup on the bottom of the carriage. I'd clean the bottom of the carriage with alcohol. =^..^=
