Canon IR 4025
  • Hoosierdaddy
    • Oct 2016
    • 181
    Canon IR 4025
    Jams but no jam found. Also the right side door alignment appears off, is there any bulletins on this series of machines about this issue? Thought there was something about prior models. Not a Canon Dealer so any help would be appreciated. Its for a non profit so trying to find inexpensive options.
    Thanks Hoosierdaddy
  • copier tech
    • 8138
    Re: Canon IR 4025
    Thanks Hoosierdaddy
    What is the jam code?
    Most likely if you have a jam but no paper found pick up did not occur so check/replace the feed rollers.
    • Canuck
      Tech Specialist
      • 1713
      Re: Canon IR 4025
      If you break or bend the plastic interlock actuator on the door, when you close the door the machine doesn't know it and won't clear the jam. Does it clear if you reboot? And need jam code
      • Hoosierdaddy
        • Oct 2016
        • 181
        Re: Canon IR 4025
        The Jam Code is 000209.
        • giogi
          Engineer senior
          • Jan 2016
          • 181
          Re: Canon IR 4025
          0209 STNRY S22 No.2 delivery sensor
          controls the functioning of the flappers.
          remove and reinsert DC connector
          Does this jam happen in front or front/rear?
          "Knowledge is a source, but unfortunately ignorance is a sea."
          • Hoosierdaddy
            • Oct 2016
            • 181
            Re: Canon IR 4025
            It jams in the front
