ImagePRESS C850
  • fatfingers73
    • Feb 2013
    • 219
    [CQ] ImagePRESS C850
    Hello all,
    Having problems fixing these two issues. Tried drums, devs, transfer units, swapped lasers and still no change.
    Going to try DC controller next, any ideas?
    Machine has only done 1.5k.
    Re: ImagePRESS C850
    Originally posted by fatfingers73
    Hello all,
    fuser failed?
    or are they using generic toner ( NON genuine OEM)
    • proditus
      • Dec 2017
      • 27
      Re: ImagePRESS C850
      Hello all,
      • fatfingers73
        • Feb 2013
        • 219
        Re: ImagePRESS C850
        Thanks, genuine toner. Image is bad on the ITB, so fixing unit fine.
        fuser failed?
        • fatfingers73
          • Feb 2013
          • 219
          Re: ImagePRESS C850
          Thanks, replaced dev and drum.
          • proditus
            • Dec 2017
            • 27
            Re: ImagePRESS C850
            Does the C850 has those glass windowed rails that stay atop off the drum unit? If so, wipe it and do an Auto Adjustment
            • fatfingers73
              • Feb 2013
              • 219
              Re: ImagePRESS C850
              Yes but they're part of the laser units and I've had them all out.
              Cheers.
                Re: ImagePRESS C850
                be nice to know ALL these LITTLE facts from the damn gitgo.
                done with you
                • fatfingers73
                  • Feb 2013
                  • 219
                  Re: ImagePRESS C850
                  Wow, who took the jam out of your donut
                  done with you
                  • proditus
                    • Dec 2017
                    • 27
                    Re: ImagePRESS C850
                    Cheers.
                    Another thing you can look at is if you made any adjustments on the gradation if that problem shows on all colors
                    • 20 year tech
                      • May 2014
                      • 577
                      Re: ImagePRESS C850
                      Do a shading correction adjustment
                      • proditus
                        • Dec 2017
                        • 27
                        Re: ImagePRESS C850
                        I couldnt remember it but it was after I made shading correction that the exact problem showed up on my other C7010. Deleted it and all it went back to normal.
                        • 20 year tech
                          • May 2014
                          • 577
                          Re: ImagePRESS C850
                          Bingo !!
                          • proditus
                            • Dec 2017
                            • 27
                            Re: ImagePRESS C850
                            Bingo !!
                            I hope fatfingers73 finds it helpful lol
                            • imran181070
                              • Aug 2016
                              • 24
                              Re: ImagePRESS C850
                              yes reset the DC CON but b4 make a p print or make backup,
                              we solved same issue by clear the dc con
                              reggards
