IRA C9060pro E074-0001
  • Cmp4you
    • Oct 2016
    • 37
    [Error Code] IRA C9060pro E074-0001
    Hi!
    I currently have an E074-0001 on a Canon IR ADV C9060 pro. It occured, when the black developer unit was reviewed due to stripes on prints.
    The ITB was left untouched. But I noticed that M5 has a strange behaviour. On startup, after ITB check, the gears on m5 go left to right (uppering and lowering the cmy rolls), but seem to stutter. I have a small clip on that: YouTube
    Is that normal behaviour? Error comes after the gears rotate.
    I managed to get it to work yesterday night so it is atleast was able to print. I changed the priority for first prints to color (so it doesnt change to black and lowers the cmy rolls). On today's startup the error comes again.
    What else can I do to fix this issue?
  • Cmp4you
    • Oct 2016
    • 37
    Re: IRA C9060pro E074-0001
    Problem is fixed. In the image below you can see my red circle around the cam. The cam was out of place on both sides of the ITB.
    The pusher was also out of place, so the cam couldn't lock itself in the pusher. Adjusting the pusher on both sides of the ITB fixed the problem.
