Double Image in Copies
  • Andyboachie
    • 185
    Hello,
    I have been working on a Canon IR C5235i. Copies appear with ghost images. After all efforts and changing developers ITB, drums and toners, I still have the same result of ghost behind the image. Could someone suggest what more I should try? Thanks I'm advance.
    Attached are copies.
    Re: Double Image in Copies
    Originally posted by Andyboachie
    Hello,
    ok COPIER 101
    what puts image on page?
    DRUMS - ITB/Transfer Roller/???
    not TONERS..
    2nd guess ?
    Not paper path from what you showed us.
    Last component?
    FUSER!!!!!
    what are the page counts on FUSER?
    did you reset counts and adjustments on things you changed?
    drums NEW OEM CANON or used/3rd party?
    as ALWAYS Andy,
    you leave IMPORTANT info out!
    PhilB "The Dentist"
    • wcanonw
      • Aug 2014
      • 404
      Hello,
      hello in the first image you sent, the ghost image is not displayed well.
      reviewing the second image you can visualize a little image with moved colors as if there were no good color registration
      • wcanonw
        • Aug 2014
        • 404
        Enter the service mode of Canon C5235
        1. SETTING REGISTRATION 28 SETTING REGISTRATION
        2. MODE LIST - COPY - TEST - PG: 6 and OK press START BUTTON
        3. MODE LIST - COPY - TEST - PG: 10 and OK press START BUTTON.
        Send picture of test 6 and test 10 to see if it is a problem of transfer unit or drum unit
        • wcanonw
          • Aug 2014
          • 404
          Hello,
          One question if you changed the ITB, you mean the transfer unit or the transfer belt. What settings did you make in the service mode? after having changed the spare parts.
          Usually when changing the transfer unit you have to make the settings related to itb for example: ITB - INIT and AT-IMG-X.
          Enter the service mode: 1. MODE LIST - COPY - FUNCTION - MISC-P - ITB-INIT and select OK
          2. MODE LIST - COPIER - FUNCTION - MISC-P - AT-IMG-X and select OK.
          • Andyboachie
            • 185
            Thanks! I changed the whole ITB unit.
            • Andyboachie
              • 185
              I'm a bit far from the machine. I'll get to work on that and get back asap.
              • copier tech
                • 8235
                Did you replace the ITB unit with a new or used one?
                If as suggested doesnt work try a DC-CON clear.
                • Andyboachie
                  • 185
                  ok COPIER 101
                  not TONERS..
                  2nd guess ?
                  Last component?
                  FUSER!!!!!
                  as ALWAYS Andy,
                  PhilB "The Dentist"
                  Thanks Phil, the drum was OEM. I'll find out the count on the fuser and get back to you. The fuser appeared so new.
                  • Andyboachie
                    • 185
                    It wasn't a new one but a farely used working one.
                    • hutmah
                      • Sep 2017
                      • 19
                      As been said i see no ghosting but a color registration issue. Have you cleaned/checked the patch sensor windows?
                      • mc007
                        reliable tech
                        • Jan 2019
                        • 28
                        Hello,
                        Registration out?
                        try to clean the patch sensors and do a auto color mismatch adjustment.
                          what is the interval in MM of the ghosting?
                          • copier tech
                            • 8235
                            This could be the cause.
                            99% of colour registration issues on Canon are caused by the ITB/Transfer unit.
                            Remove the belt from the ITB thoroughly clean the rubber drive roller & the inside of the belt, refit & test again.
                            • doktor
                              • 215
                              Send first TEST PAGE 6 AND 10.
