Canon c5045 developer
  • howling
    • Feb 2019
    • 35
    Hi guys,
    just wondering if someone out there have tried or done this kind in a canon c5045 ...the developer is shot so i was wondering has anyone tried refilling it or Its an assembly period....no separate developer ( or beads as we call it in xerox) that you can order.
  • JPiek
    • Oct 2014
    • 435
    Re: Canon c5045 developer
    Developer is just the assy, if you allready tried a STIR' in the Servicemenu, replace the assy, if te coupling is FUBAR, you can order that seperatly...
    FM4-8354-010 1 DEVELOPING ASSEMBLY, BK BLACK[DP]
    FM4-8353-010 1 DEVELOPING ASSEMBLY, C CYAN[DP]
    FM4-8352-010 1 DEVELOPING ASSEMBLY, M MAGENTA[DP]
    FM4-8351-010 1 DEVELOPING ASSEMBLY, Y YELLOW[DP]
    FC0-3696-000 4 COUPLING
    XD9-0289-000 4 PIN, PARALLEL
    Johan
    • howling
      • Feb 2019
      • 35
      ok thanks man my bad...what i was wondering was the beads(carrier) i think its called developing, im really not sure if that is the proper term for it (coz in xerox we just call it beads)...but i really appreciate your reply mate..cheers
      anywho has anyone done it before..i mean just refill the developer with carrier (beads , developing etc)...cause its a pain to find the whole developer here in saudi even the supposed dealer dont have it so i was wondering if what i was thinking is a possibility or not otherwise i have no choice but to wait 2 months for the spares.
      • JPiek
        • Oct 2014
        • 435
        Carrier aka "developing powder" can only be bought seperatly als NON_OEM, I would advice against it as I assume getting a new drum wil set you back 2 months also...
        Worst case get an old dev.assy form another machine, print the specific color until the 'old' color is out..
        Johan
        • copier tech
          • 8136
          Originally posted by howling
          Hi guys,
          What makes you think your developer unit is shot? you can't buy the developer powder separately it comes with a complete developer unit (prefilled)
          • giogi
            Engineer senior
            • Jan 2016
            • 181
            If the developing group is slightly emptied, you can add some toner powder by hand by opening the developing group.
            This powder is a mix of toner and developer.
            Important not to launch COPIER > FUNCTION > INSTALL > INISET- X
            The previous concentration value is stored in the machine
            The copier alone will resume the correct concentration of DENS (.+ - 0%)
            "Knowledge is a source, but unfortunately ignorance is a sea."
            • howling
              • Feb 2019
              • 35
              now that is what i want to know...thanks man guess i have to put the machine in the graveyard for now
