Canon IRC2220
  • Fuzzylogic
    • Aug 2016
    • 33
    [Misc] Canon IRC2220
    Hello All
    The touch panel on this machine was not working properly. If you touched the Copy icon it would take forever to respond, and sometimes didn't do anything. If you tried to touch any other icon on the panel there was little or no response, so I changed the Touch Panel itself. The machine still does the same thing..............little or no response from the touch panel. The machine still prints O.K. but nothing through the Touch Panel. Any ideas?????????????
    Regards
    Fuzzy
  • copier tech
    • 8138
    Re: Canon IRC2220
    Originally posted by Fuzzylogic
    Hello All
    Regards
    Fuzzy
    There is a bulletin on this. The control panel CPU is/is failing & needs to be replaced. See attached pdf.
    IRAC 22xx failure of the touch panel and keypads.pdf
    • hidius
      • Jun 2015
      • 128
      Re: Canon IRC2220
      try updating the firmware. if still the same, format the hard drive and do the firmware. if still the same replace the hard drive
      • Brian8506
        • 1664
        Re: Canon IRC2220
        CPU failure very common on this model
        Sent from my iPad using Tapatalk
