Colours different
  • zuckryyu
    • Jul 2019
    • 31
    [CQ] Colours different
    Im using canon ir advance c5235
    But whenever i print colours from my pc,the output became different from what i print (the colours)
    From grey became dark blue
    Any help from the experts? Tried calibration,nothing changes
    Sent from my TA-1021 using Tapatalk
  • MunsterTech
    • Sep 2014
    • 380
    Re: Colours different
    make sure you have the correct driver installed
    • wcanonw
      • Aug 2014
      • 404
      hello with what type of driver are you printing: UFRII, PCL, PS or imagepass pass server B2?
      • wcanonw
        • Aug 2014
        • 404
        if the printer is installed with imagepress server B2 you can modify the colors by moving the output profiles using the command work station program
        • wcanonw
          • Aug 2014
          • 404
          if your controller is PS (postscript) you can try what the PDf file indicates
          • wcanonw
            • Aug 2014
            • 404
            Could you indicate how you performed the calibration if it is with the full gradation adjustment, grayscale or ES1000 spectrophotometer?
            • wcanonw
              • Aug 2014
              • 404
              If the driver is UFRII, the print quality is usually dark or saturated, try the PS driver and if you have SERVER B2 download the appropriate driver
              • zuckryyu
                • Jul 2019
                • 31
                Thanks.....im already do it...it works
