Toner cyan sign
  • zuckryyu
    • Jul 2019
    • 34
    [CQ] Toner cyan sign
    Does any experts here know this problem
    Change toner hopper--- yes
    Toner hopper motor----yes
    New toner-----yes
    Sent from my TA-1021 using Tapatalk
  • wcanonw
    • Aug 2014
    • 404
    Re: Toner cyan sign
    New toner-----yes
    hello you already tried to open FIXING / FEED ASSEMBLY, turn on the printer and enter the service mode: COPIER-FUNCTION-CLEAR-ERR_OK you turn off and turn on the machine when the screen tells you to close the door, close the FIXING / FEED ASSEMBLY and main door
    • wcanonw
      • Aug 2014
      • 404
      Re: Toner cyan sign
      the other would be to take out the BOTTLE EXCHANGE COVER ASSEMBLY, activate the sensors with pieces of paper and put the toner bottle, check if the cyan toner bottle is rotating
      • wcanonw
        • Aug 2014
        • 404
        Re: Toner cyan sign
        Remedy:
        Identify the cause of the error whether it is due to
        mechanical problem to open/close the Toner Cap or
        problem at the Toner Container Cam HP Sensor side. ■
        1. Check if the Toner Container Cam HP Sensor is soiled
        and the installation of the sensor. ■
        2. Rotate the Set-on Drive Shaft a little with the attached
        tool, and check the service mode (COPIER> I/O> DCON>
        P024 bit6) to see that the output value of the sensor is
        changed. ■
        Since it is difficult to check the screen while rotating it,
        repeat the operation to rotate it a little and check the
        screen until the value is changed. ■
        If it is normal, the output value of the sensor is changed
        when opening/closing the Toner Cap. Even if it is normal,
        be sure to perform step 4 and later steps. ■
        2-1. If there is an error in rotation of the Set-on Drive
        Shaft, check the drive system such as gears. ■
        If it is damaged, replace the Set-on Drive Unit and then
        2-2. When the Set-on Drive Unit is not driven although
        the Set-on Drive Shaft rotates, check if it is driven by
        removing the Hopper Unit. ■
        If it is not driven, replace the Hopper Unit and then
        2-3. When the output value of the sensor is not changed
        although the Set-on Drive Unit is driven, check the Sensor
        Harness (to see if the harness is caught, disconnected or
        physically removed). ■
        If there is no problem, replace the sensor. After checking
        the output value in step 2, perform step 4 and later steps. ■
        3. If the problem is not solved by replacing the foregoing
        parts, replace the Drum Driver PCB (UN4) and then
        4. Clear the error in service mode (COPIER>
        FUNCTION> CLEAR> ERR), and then turn OFF and then
        ON the main power. ■
        5. Replace the toner (reinstall the removed Toner
        Container) at least once in user mode (Adjustment/
        Maintenance> Replace Specified Toner), and check that
        toner replacement can be performed normally
