Canon Ir 1435if jamming every 10 copies at pick up
  • sly
    • Feb 2016
    • 37
    Canon iR 1435if is jamming at Sep/feed rollers around every 10 copies. fitted new pick up and feed/Sep rollers. Making a loud noises before jam occurs. have had a look at drive system but not removed yet.
    Any thoughts folks please.
  • Brian8506
    • 1664
    Re: Canon Ir 1435if jamming every 10 copies at pick up
    Don't really have jam issues but did you check and make sure the pick up rollrs are snapping back into place? There's a spring that pulls them back to home postion that I've had come off.
    • sly
      • Feb 2016
      • 37
      • giogi
        Engineer senior
        • Jan 2016
        • 182
        see attach
        "Knowledge is a source, but unfortunately ignorance is a sea."
        • Copylady72
          • Jul 2019
          • 35
          What kind of noise? I had a machine that made a very loud rubbing noise as it was feeding paper. It jammed intermitently.
          It ended up being the torque limiter on the feed separation roller shaft.
          Part# FE4-4179-000
          Sent from my SM-N950U using Tapatalk
          • sly
            • Feb 2016
            • 37
            Thank you folks for your replies. both with useful information. Will order the new torque limiter as it does sound like that of the hard rubber separation roller binding causing jams . Will also check the lever behind the pick up shaft gear at rear of machine for excess grease. Will keep you posted later this week thanks.
            • techandtrader
              • Jun 2016
              • 330
              What was it?
              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                Have seen the gear tips wear, the one that engages when solenoid releases it.
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                • Canuck
                  Tech Specialist
                  • 1713
                  Torque limiter. Changed a few on these...grunts when it feeds
                  • wingit
                    • Feb 2011
                    • 84
                    I had this on the optional 2nd paper tray, and replaced all the rollers,torque limiter.Still double clutching and jamming.
                    It ended up the solenoid pawl needed to be filed down so more of the pawl was holding back the sleeve part. and I used a spring from a hplj 4250 solenoid spring.
                    Give a man a fish he eats for a day,Teach a man to fish he eats for a Life time.
                    • techandtrader
                      • Jun 2016
                      • 330
                      Maybe the most expensive torque limiter for a machine this size. Around $25. I will pick one up soon and report if anything is remarkable. Thanks for posts.
                      • NM0174
                        • Mar 2013
                        • 38
                        So what was the problem? You didn't come back
                        Sent from my SM-G965U using Tapatalk
                        • sly
                          • Feb 2016
                          • 37
                          Torque limiter resolved the problem. Thanks you all for your thoughts.
                          • techandtrader
                            • Jun 2016
                            • 330
                            So I had an optional tray with the same TQ Limiter. DID NOT WORK! Same noise remains. There is no evidence of roller rubbing like flat spots or pieces. The box was manufact in 2015.
                            I cant find another reason.
                            • Gary71
                              • Sep 2020
                              • 1
                              I have seen the seperation roller housing get worn and cause this. I had 2 in the past month and once changed along with the roller resolved the issue. FYI
