Canon IPF670 Printhead Error Problem
  • wcanonw
    • Aug 2014
    • 404
    [Error Code] Canon IPF670 Printhead Error Problem
    The plotter shows spindle error 03800300-2832, and also at times there will be a message of "ink absorption please wait", then ink begins to leak from the purge system and waste cartridge is already collapsing due to excess residual ink
  • wcanonw
    • Aug 2014
    • 404
    Re: Canon IPF670 Printhead Error Problem
    the supplier that sold the plotter to the customer, from the beginning the plotter was put in affordable ink and continuous ink system. When the customer asked for the original ink cartridges, they assured him that with the continuous system he would print without problems.
    It's been half a year and the plotter started with that problem
      • 23003
      • wcanonw
        • Aug 2014
        • 404
        The seller sent his technician, the technician made a hole in one of the continuous system ink cartridges and ended up blaming the customer and plotter users, to get rid of the warranty, I told the customer that you lost the warranty from the beginning to allow them to install them in front of the compatible ink ....
        Now when the customer calls the supplier and they only tell him to buy the PF-04 printhead
          • 23003
          Compatible ink? Even better.
          Yes, no warranty, and I wouldn't touch it with a 10 foot pole. =^..^=
          • wcanonw
            • Aug 2014
            • 404
            yes compatible ink
            • wcanonw
              • Aug 2014
              • 404
              attached photos of the plotter canon ipf670
              • wcanonw
                • Aug 2014
                • 404
                whit compatible ink
                  you keep solving the problem
                  COMPATIBLE INK
                  BUY THE PRINTHEAD INSTALL IT.. PURGE THE SYSTEM.. GO BACK TO CANON INK
                  • wcanonw
                    • Aug 2014
                    • 404
                    COMPATIBLE INK
                    I was going to update the firmware, check on the main canon page and the version of the firmware that the plotter has is the last one on the canon usa website
                      • 23003
                      I haven't seen a question yet. =^..^=
