Canon IR ADV. 6255 doc. feeder hinges
  • jper34
    • Sep 2011
    • 225
    Hey Folks,
    Let me throw this out there..Only when using doc. feeder, on top trail edge of copy I get a littly shading, and copier does call to "clean dirty slit glass", after thinking , hard and long it came to me, the doc. feeder hinges, or rear hinge. I went back today to see if I could adjust the height, as I did eyeball it out, and feeder isnt sitting proper on the glass. I didn't have any luck, to get it to adjust properly, anyone else have this issue, on this model?..
    Also, would anyone be able to help me out the part #, for the hinge?
    Thanks..
    Jaime
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Canon IR ADV. 6255 doc. feeder hinges
    The ira 62xx series has a G1 colour image reader
    FC8-5778-000 right hinge
    FC8-5777-000 left hinge
    But I've never had to replace the df hinges on this model they are heavy duty if the lid isn't slamming down or twisted hinge
    Regards Mark
    • 20 year tech
      • May 2014
      • 580
      before you replace hinges (Ive never had to that on this model either) Check that the white roller over the stream reader glass is seated properly. I have seen sometimes it can get pushed up into the frame and doesn't sit properly causing the problem you describe.
      • jper34
        • Sep 2011
        • 225
        Thanks...Im going to try that white, as I did clean it, then it did make bouncing noise, then went away...but I bet your right,..I will check that white roller..and let you know what I may find..THANKS !!!
