IRC3200 0205 Duplex jamming
  • PoonKing5000
    • Jun 2008
    • 111
    I have a machine that reads a 0205 Jam code when running multiple pages duplexed. If i run one copy it runs fine. There is always one page halfway through the fuser on the second side and the second page is coming out of the duplexer halfway through the registration assembly. The second page is reading the jam but it only happens when running multiples. I have replaced the right side door assembly and cleared D-Con. There is nothing blocking either pages. Any ideas?
  • kwazimoto
    • Jan 2007
    • 199
    Ok here are a few things.. jams only on letter try cleaning duplex rollers and fuser inlet roller.. next have had trouble with DC controller also duplex motor and duplex driver pcb.. duplex reg. clutch fh6-5052-020 new mod clutch... also check guide under the fuser it wraps fm2-6099 that would be were I would start .. hope this helps
    • Oze
      Ricoh Fanboy
      • 1663
      Also try replacing the duplex guide plate(under the fuser) with the new modifed version.
      The old plastic version warps with the heat and interferes with duplexing.
      • PoonKing5000
        • Jun 2008
        • 111
        That plate was cracked and broken but was replaced and made no difference in the jamming.
        • Oze
          Ricoh Fanboy
          • 1663
          Replace BOTH clutches in the duplex.
          The one on the front of the assy and the one at the rear...also check shafts to see if the bearings have failed and chewed out the shafts.
          • PoonKing5000
            • Jun 2008
            • 111
            I replaced the whole Left side assembly minus the fuser and door assembly and that corrected the issue. When i get some time i will try to figure out exactly what the issue was with a machine here in the shop. I will check out all the clutches and bearings in that assembly and see if they were a problem.
