Ir 6000 only green light on. No power
  • ilidasgaming
    • Jan 2020
    • 6
    [Dead] Ir 6000 only green light on. No power
    My machine is working fine. But after i did not use for 1 month. The machine is not working. No power, only green light indicator. I already tried reseat all the ram and bootrom and try another ram, reseat all in dc con and main. Thanks
  • kuby
    • Oct 2007
    • 1373
    Re: Ir 6000 only green light on. No power
    Try taking the display unit out and cleaning it and around where it contacts the frame. Sounds strange but if I remember right it can be a grounding issue with the display / control panel.
    • vigour
      • Aug 2010
      • 1038
      That is usually a sign that your main controller is defective
      Sent from my SM-G950U using Tapatalk
      • ilidasgaming
        • Jan 2020
        • 6
        Suddenly the machine is have power now. I dont know why. I didnt do anything After 1 day and have error 000733-0001 and i reseat cables from main,rcon and dc con. Then after 10mins. The lcd start blinking 5, sec.Then machine is no power again.
        • kuby
          • Oct 2007
          • 1373
          I had a issue with one doing the same thing. Someone on this site told me to try taking the display unit out and cleaning it and around where it contacts the frame. Sounds strange but if I remember right it can be a grounding issue with the display / control panel. I thought that it did not make sense to me but what did I have to lose. It worked for me and did not have another issue with it.
          • ilidasgaming
            • Jan 2020
            • 6
            Yeah sound strange. But i try this. Thanks for the reply
            • ilidasgaming
              • Jan 2020
              • 6
              Does your machine had same error 733-0001? When it come back the power on?
              • kuby
                • Oct 2007
                • 1373
                No it just came back on to the Ready and was able to make copies.
                • techandtrader
                  • Jun 2016
                  • 318
                  Does the machine shock you sometimes when you first touch it? I had this error in a C5000 and was not able to stop it after changing power supply's and boards. I think it could have been a grounding problem. It was a shop machine so it is no longer in service.
                  I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
                  • ilidasgaming
                    • Jan 2020
                    • 6
                    No it didnt shock me. How do you fix your machine?
                    • ilidasgaming
                      • Jan 2020
                      • 6
                      I borrowed power supply then i put in my machine. The machine have power now with no error and working fine. Then after a day the machine is no power again. Then i put the my old power supply , the machine have power again. After an hour the machine is no power. What do you think guys? If the machine have a grounded or shortage wire it is possible to damage the power supply?
                      • Soni Kusdiantoro
                        • Oct 2016
                        • 12
                        CEK all SENSOR CASSETE (up)
                        i don't now what thast call in english
