Missing FEEDER MENU on service mode
  • okimaestro79
    • Jan 2017
    • 8
    [Electrical] Missing FEEDER MENU on service mode
    Hi all... I have trouble with Canon advance 6075... After replacing CCD unit ..on service mode the FEEDER Menu wae deseapper..no menu FEEDER...please help..thanks
  • Momiowilove
    • Sep 2019
    • 63
    Re: Missing FEEDER MENU on service mode
    Do you try to reset the rcon or the ccd in the service mode?
    Sent from my RNE-L22 using Tapatalk
    • wcanonw
      • Aug 2014
      • 404
      hello good morning because problem or error did you change the ccd?
      • okimaestro79
        • Jan 2017
        • 8
        CCD unit no eror..not change the CCD..only cleaning scanning lamp and glasses
        • copier tech
          • 8164
          Why did you replace the CCD?
          Does the Document feeder work ok?
          • hidius
            • Jun 2015
            • 128
            the menu doesnt show because there is something wrong with the reader unit. is there power to the reader unit? doese the light come on when you close the adf lid?
            • wcanonw
              • Aug 2014
              • 404
              hello when you turn on the printer, does the dadf intermittently emit a mechanism sound or place a paper in the dadf and should the LED that detects the paper turn on?
              replace or discard:
              - the dadf driver pcb or adf unit (dadf).
              - the Reader Controller PCB or reader unit
              • giogi
                Engineer senior
                • Jan 2016
                • 181
                Please check this item
                COPIER > OPTION > FNC-SW > W/SCNR
                must be 1
                "Knowledge is a source, but unfortunately ignorance is a sea."
                • Mr Magic
                  • Jan 2020
                  • 29
                  Your device may have gone into limited function mode. Will need to calibrate CCD/Scanner. See manual for details.
