c5235 copy from the Feeder
  • bugtom
    • Sep 2019
    • 2
    Scanning from the Platen Glass no promble.
    Image is Completely Black, when Scanning from the DADF.
    • 22808
    Re: c5235 copy from the Feeder
    does the sheet feed all the way thru?
    does the scan lamp light up?
    any error codes?
    there can me multiple reasons.. need more info
    • giogi
      Engineer senior
      • Jan 2016
      • 180
      If you make a copy of the plate, how does it look?
      please give us more details
      "Knowledge is a source, but unfortunately ignorance is a sea."
      • bugtom
        • Sep 2019
        • 2
        yes. no problem
        When the paper passed halfway.
        The lamp lights up for 1-2 seconds and then turns off.
        I think this is a problem.
        any error codes?
        No error codes.
        a copy is black, Same as the black toner test.
        Thank you so much.
        • wcanonw
          • Aug 2014
          • 404
          hello, replace pcb reader
          • MunsterTech
            • Sep 2014
            • 376
            did you try a R CON clear? had a really weird cq issue a while back only using the dadf, did a r con clear and hey presto it worked fine after
