Canon IR2200 Shows Jam
  • doug
    • Dec 2011
    • 198
    Hi Guys,
    I have a canon IR2200 that shows a jam on the right hand side of machine...there is no paper there and machine will not clear.
    Any input?
    Thanking you in advance,
    Doug
  • GIUBOSS
    • 1398
    Re: Canon IR2200 Shows Jam
    better to check if some paper passage sensor is out of place or blocked by a small piece of paper, remove the paper trays and check inside the machine, the reset works even if it closes all the doors correctly.
    • Andyboachie
      • 185
      Hi,
      In addition to Giuboss' suggestion, check the state of springs on sensor flags. Also check the state of sensor flags close to pickup rollers and in duplex areas.
