Canon scanner error codes
  • Shaker
    • Oct 2019
    • 7
    Does anyone have a list of error codes for the Canon scanners DR-G2110
    Re: Canon scanner error codes
    in the service manual for that option.
      • 16083
      Lucky Day
      • Shaker
        • Oct 2019
        • 7
        Thank you for the reply.
        The error codes i'm getting are
        EO46
        EO54
        121
        is there another list?
          • 16083
          EO46
          EO54
          121
          Scanner hardware problem.
          Exxx = Internal scanner error.
          Turn the power OFF, and restart the scanner.
          Ifthis does not solve the problem, make a noteof the error code, and contact your Canonservice representative.
          If a communication error occurs between the motor or sensor and PCB, an error mes- sage and code “Exxx appears.
          If it appears, reset the main body and computer power. If the message still appears, check the error code, and then check the connection of the related part, and if it is faulty, correct it.
          If there is no problem with connections,
          replace the related part.
          For motors, check the connected drive transmission parts and operation check sensor as well.
          Code Parts/symptom
          E011 Pickup up/down motor E012 Feed motor
          E020 Main motor
          E021 Tray motor
          E022 Separation motor
          E024 Eject motor
          E025 Pickup motor
          E030 Exhaust fan
          E032 Control PCB model error
          E033 Shading motor (front)
          E034 Shading motor (back)
          E039 Cooling fan
          E040 Sub-drive PCB
          (Man drive CPU judgment)
          E041 Main drive PCB
          E044 Ultrasonic drive PCB
          E046 Main drive PCB
          (Controller CPU judgment)
          E048 Eject PCB
          E049 Sub-drive PCB
          E054 Reading unit (front)
          E055 Reading unit (back)
          E086 Control EEPROM write error
          E101 Pickup tray timeout error
          E102 Pickup sensor timeout error
          E103 Document sensor timeout error
          E104 Shading move timeout error (front)
          E105 Shading move timeout error (back)
          E851 CIS data error
          E860 Shading data timeout error
