Tricky wiggly line on IR ADV 6255 copy
  • sittingpretty
    • Sep 2015
    • 34
    This black wiggly line keeps appearing on my copies be it in service mode tests and in platen glass copy. Drum blade checked, developer checked, drum claw new, primary and secondary wires checked, ETB new, ETB blade new...as copies progress line becomes more distinct like a freehand technical pen scribble. Help please. TY in advance.
  • rapo_tech
    • Feb 2019
    • 114
    Re: Tricky wiggly line on IR ADV 6255 copy
    Scan a sample for us.
    • Brian8506
      • 1665
      Did you clean the grid real good on the primary?
      • sittingpretty
        • Sep 2015
        • 34
        This is how it looks.
        • sittingpretty
          • Sep 2015
          • 34
          Those of you who might encounter this in the future, might want to check the pre exposure lamp area for adhesives and foreign elements, found the culprit inside that area. Thoroughly cleaned that area and copies were back to clean and clear. Thank you for your concern fellow Techs. Keep on sharing.
            • 23009
            This can be an issue on any laser based device, but especially Sharp. You must minutely examine everything within 1" of the drum surface. Lint or fiber can statically cling to a drum blade, cleaning lamps, or a nearby crossmember, and when the drum is charged up that fiber dances. I'd see this especially after a PM. You wipe down literally everything within 1" of the drum, put it together, and find that you've moved your nearly invisible fiber 2" to one side or the other. =^..^=
            • jamal121
              • 10
              Hello, I faced the same problem and a piece of plastic was in the form of a thin thread over the primary base. I must use a light from the devloper unit side to see it.
              • Robert Silva
                • Jan 2019
                • 35
                Hello. I already came across a similar risk. In my case, I identified an accumulation of toner in the same direction as the defect in the developer unit. It was in the developer structure itself, just below the magnetic roller.
                • Canuck
                  Tech Specialist
                  • 1713
                  Pull the process unit, seal glass and chargers out. There might a dust bunny or something in the path of the laser light...blow out the seal glass area with a rolled up sheet of paper. As mentioned, could be lint, etc on primary assembly also
