Canon ir 7105 giving error 567-8001 cleaned all sensors, changed all boards, still not able to solve the problem, pls help, thanks in advance.
Canon ir 7105 e 567-8001
Re: Canon ir 7105 e 567-8001
E567 8001 - fault in shift roller unit HP sensor or horizontal registration shift motor
The shift roller unit HP sensor does not
go off within 5 sec after the start-up of
the horizontal shift motor.
- Check the connectors of the horizontal registration
shift motor and the shift roller unit HP sensor.
- Replace the horizontal registration shift motor and the
- Replace the finisher controller PCB.
this is related to finisher so you need more time to disassembly of this unit
