Canon ir 7105 e 567-8001
  • Saji
    • May 2010
    • 97
    Canon ir 7105 giving error 567-8001 cleaned all sensors, changed all boards, still not able to solve the problem, pls help, thanks in advance.
  • rudysemira
    • Oct 2016
    • 108
    Re: Canon ir 7105 e 567-8001
    Did you clean all the sensors? Which part did you clean?
    E567 8001 - fault in shift roller unit HP sensor or horizontal registration shift motor
    The shift roller unit HP sensor does not
    go off within 5 sec after the start-up of
    the horizontal shift motor.
    - Check the connectors of the horizontal registration
    shift motor and the shift roller unit HP sensor.
    - Replace the horizontal registration shift motor and the
    - Replace the finisher controller PCB.
    this is related to finisher so you need more time to disassembly of this unit
