IR 2318 Service Code not Responding
  • Andyboachie
    • 185
    Hello,
    I have a situation on hand with Canon IR 2318 copier. I have an E-0000-0001 and wants to enter into service mode to clear it. However, the key combination of *28* does not send me into the service mode. It rather remain unresponsive. I wish I could get a suggestion from colleagues with similar experiences to get round it.
    I will be thankful.
  • Brian8506
    • 1665
    Re: IR 2318 Service Code not Responding
    You may have to enter service mode by Addl func/2 THEN 8/Addl func as opposed to 2&8 at same time
    • Andyboachie
      • 185
      Thank you for the response. I tried that and it did not work. I really don't know what might be the cause. I know some earlier versions of the IR used to have the code entered in succession instead of the 2&8 pressed at the same time.
      I'm just wondering what else I have to do or what I have to replace.
      • mosey1100
        • Mar 2009
        • 143
        You need to replace the fixing film unit to clear the error code.
          and clear the counter on the film... but you might as well rebuild replace whole unit.
          • Andyboachie
            • 185
            I will work on that tomorrow and see which of the two options helps.
            • copier tech
              • 8174
              Even after you fit a new fuser/film you will still need to clear the code in service mode.
              YouTube
              • Andyboachie
                • 185
                YouTube
                Thanks pal for the video. I hope to make use of it once the the actual trouble is over.
