Canon IR C5035 printing problem need help to diagnose please see pictures, thank you.
  • maxcopiers
    • Dec 2019
    • 15
    Re: Canon IR C5035 printing problem need help to diagnose please see pictures, thank
    Originally posted by maxcopiers
    [ATTACH=CONFIG]45067[/ATTACH][ATTACH=CONFIG]45068[/ATTACH]
    what are the counts on PM parts?
    is the machine clean?
    what does the belt cleaner look like.
    a picture doesn't always "say a thousand words"
    • MunsterTech
      • Sep 2014
      • 381
      looks like the cleaning blade assy for the ITB just by looking at the pics, as Phil says, check your durable counters etc
      • copier tech
        • 8188
        Take the ITB cleaning blade off, give a clean re fit back & test. If this resolves the issue order a new one.
        • Desert Rat
          • May 2008
          • 1089
          Ditto,
          DR
          • maxcopiers
            • Dec 2019
            • 15
            Thank you for the help. I checked the ITB assy. ITB cleaning unit was loose and causing build up where the cleaning blade meets the belt. Tightened the screws and cleaned up. Thank you, problem solved now.
            • Desert Rat
              • May 2008
              • 1089
              maxcopiers,
              Thank you for posting your solution. It will help us all to remember to check things out
              and not just say,"I don't know?"
              I have found lots of problems by first taking the suspected unit out for inspection. A lot of the times
              it is something simple, like loose screws or a small piece of plastic in a connector.
              Glad you fixed the copier
              DR
