Scan IR C2380i
  • occus
    • 337
    Scan IR C2380i
    Can somebody give me a tip to install the IRC2380i scan to smb on a Win10 networkfolder?
    Host //IP
    Path /Scanfoldersharename
    Login Admin (had tried the SystemAdmin too)
    Pw xxx
    Are the slashes right?
    Is SMB2 supported or only SMB1?
    Share settings are all correct!
    I get always connection errors.
    Thank you.
  • MunsterTech
    • Sep 2014
    • 381
    Re: Scan IR C2380i
    you will prob have to download special firmware from SIMS that allows smb scanning
    • occus
      • 337
      Re: Scan IR C2380i
      The scanfunction has already worked on a Win10 PC.
      But the customer has replaces his PC...
      Now i have problem and ask for the right settings.
      Unfortunately i can't found the information on canon's public information area. I'm only familiar with Konicamonolta Kyocera and Brother.
      • copier tech
        • 8174
        Re: Scan IR C2380i
        Host //IP
        Pw xxx
        Thank you.
        Only SMB v1 is supported on this old model.
        Most likely his new PC has SMB v1 disabled due to a known security risk.
        You can turn this back on should you wish from Programs & features. turn Windows features on & off. Check SMB v1 is checked.
        • occus
          • 337
          Re: Scan IR C2380i
          Yes SMB1 i have re-activated already but the error persists. Send Error 751
          Can you tell me should i use the slash characters \ or not?
          \\SERVERNAME
          \Scanfoldersharename
          admin
          password
            • 30295
            Re: Scan IR C2380i
            • occus
              • 337
              Re: Scan IR C2380i
              I got it to work with ftp... and its ok now.
              Thank you for your support.
