henry
  • henry1
    henry
    i have a canon image runner c 5800,,with a code E000004-0042,,how can i rest this code,and do i need to replace thermostat,,or temp,fuses..please help
  • zaza
    MECANOGRAPHE
    • Mar 2008
    • 1095
    hi friend henry ..can you tell me your mail ..l can find you the manual of this copiers ....if there he can healpe you ...
    BEST TECHNICIAN . NICE PEOPLE .
    • SCREWTAPE
      • May 2025
      Go to service mode, hit > additional function> 2 and 8 then additional function again, Copier>function>clear>err and press ok. Reboot machine, if the code comes back check the rear and fixing terminal connectors. Check heater lamps, thermo switch and thermistors, aslo check the condition of the fixing rollers and see if they have flat spots. Good Luck,
      ScrewTape!
      • henry1
        hello zaza,,how you doing,,,
        thanks for your help..i try to do what you told me to do, but no luck,,the machine go to a warm up and dont, let me in services mode,,how can i get in to the services mode,,
        • SCREWTAPE
          • May 2025
          Access Service mode * 2 then 8 * From the control panel. Is the fixing ass'y getting at least getting warm, can you check to see if the heater lamps are going on. E004-0042 is not in the book.
          E004 Code
          Detail
          Cause/Particulars of detection
          Remarks
          E004
          There is an error in the fixing assembly protection circuit.
          There is an open circuit or poor contact in the main thermistor (THM1, THM2, THM3) or sub thermistor (TH4, THM5, THM6). The AC driver PCB or the DC controller PCB has a fault.
          0001
          There is an SSR error in the outside heating roller heater.
          Check the main thermistor and the sub thermistor for an open circuit and poor contact; then,turn off and then on the main power.
          0002
          There is an SSR error in the fixing sub heater.
          0003
          There is an SSR error in the outside heating roller heater or the fixing sub heater.
          0004
          There is an SSR error in the fixing main heater.
          0005
          There is an SSR error in the outside heating roller heater or the fixing main heater.
          0006
          There is an SSR error in the fixing sub heater or the fixing main heater.
          0007
          There is an SSR error in the outside heating roller heater, fixing sub heater, or fixing main heater.
          0008
          There is an SSR error in the pressure heater.
          0009
          There is an SSR error in the outside heating roller heater or the contact heater.
          000A
          There is an SSR error in the fixing sub heater or the contact heater.
          000B
          There is an SSR error in the outside heating roller heater, fixing sub heater, or contact heater.
          000C
          There is an error in the fixing main heater or the contact heater.
          000D
          There is an SSR error in the outside heating roller heater, fixing main heater, or contact heater.
          000E
          There is an error in the fixing sub heater, fixing main heater, or contact heater.
          000F
          There is an SSR error in the outside heating roller heater, fixing sub heater, fixing main heater, or contact heater.
          0010
          The fixing roller thermistor has an open circuit.
          0020
          The outside heating roller thermistor has an open circuit.
          0030
          • henry1
            Thanks i will try to do that on monday,,,i thinking now thiers is no heater lamp caming on,,,usually is the thermistor,or the temp,fuse..thanks
