Canon ADV 5030 Control Panel Hold Up
  • Andyboachie
    • 185
    Hello,
    I tried to restart Canon IR ADV C5030 after I cleared error code. But the restart could not go through because the progress bar in the dark background was taking an unusually long time to move further. I had to end the day's work, because I had waited for over 25 minutes without successfully restarting.
    Is there any thing I can do to save the situation? Thanks in advance.
  • copier tech
    • 8235
    Re: Canon ADV 5030 Control Panel Hold Up
    Originally posted by Andyboachie
    Hello,
    What was the error code?
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Hello,
      Hard drive
      Try system software
      If no good replace hard drive and load system software if must be the correct hard drive {Canon}
      Regards Mark
      • whymylittle
        • Oct 2019
        • 2
        Must check hdd
        • Andyboachie
          • 185
          Well it was an E-0000-001 code which occurred after the machine was turned on for a long time.
          • Andyboachie
            • 185
            Originally posted by mga
            Hard driveTry system software If no good replace hard drive and load system software if must be the correct hard drive {Canon}
            Thanks for this suggestion! I'm a bit far from the place. I will work on and return with a feedback.
