canon ir5051 cant start normal.Just green light only
  • Nizam HS
    • Mar 2020
    • 13
    [Dead] canon ir5051 cant start normal.Just green light only
    Hello...any suggest to solve this problem..i was change all supply power board (Ac driver,all night power,main controller 1..it still same,😭
    • 22808
    Re: canon ir5051 cant start normal.Just green light only
    what troubleshooting methods led you to replace ALL those boards?
    did you even look at the HDD?
    are you a trained Canon tech?
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Why would you start fitting boards. You should of start asking questions 1st if could be as simple as a hard drive problem
      Regards Mark
      • Nizam HS
        • Mar 2020
        • 13
        HDD...??but what about the sound came out from power supply area,its like clicking-clicking
        • Nizam HS
          • Mar 2020
          • 13
          About the sound like clikk,clikk?
          • Andyboachie
            • 185
            Yeah! I go with Phil B. Even if there is a sound like that, it is better to be adventurous a bit. Did You open the back of the machine, and turn the machine on to see exactly where the sound was coming from? Was it coming from the power board, or any of the boards you changed? That unusual sound is mostly the sound of a dying HDD. But if your situation is different, did the clicking sound go when you changed the boards? If it did not, then look for a culprit that is more of mechanical than electronic.
              • 22808
              HDD make click click click sound too!
              do you even work on these units for a living ?
              • Nizam HS
                • Mar 2020
                • 13
                Dying HDD...i was change it,but still same ..On the suis but still only green light appear,and blank panel
                • Nizam HS
                  • Mar 2020
                  • 13
                  Now,after i changing the supply board,the sound click click was gone..so confuse,but still same,the machine cant run normaly..
                  • Andyboachie
                    • 185
                    Once it is a sound that repeats itself, open the back look closely/listen carefully. You'll surely find at least the source of the sound. Also, you may find it useful to check at the fixing unit, since that area may generate such sound after a wear gears.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Give up call a Canon Service engineer who would know what to do
                      Regards Mark
                      • Ray.lb
                        • Mar 2019
                        • 14
                        Hello nizam
                        when you push the power button of the machine do you hear any mechanical activity
                        Any moving motors or gears. Is it just a dead screen or the Machine is completely dead.
                        I has had the same issue with a canon iRA C7055 the machine was completely shut down with no activity
                        The problem was the DC power supply
                        The machine came back to life and worked properly after replacing the DC power assembly.
                        Hope my answer leads you to the proper solution.
                        Sent from my iPad using Tapatalk
