Canon IR 4235 42XX help to identify noise from machine
  • maxcopiers
    • Dec 2019
    • 15
    when the right door is opened and closed, i hear the noise making 8-9 rotations rapidly. the noise rotations occur almost in sync with the Reversal Motor, starts and ends a second before. Running just the Reversal Motor does not making the noise unfortunately. i have tried running all the motors individually in service mode using MTR-ON, but cannot hear same sound as when right door open and close. any help, thank you.
    Noise occurs after shutting right door. 3 seconds into video, 8-9 rapid rotations, lasting 1-2 seconds.
    Video
    Noise also occurs during copying. Near end of video (@15 sec) for one second, noise makes 4-5 rotations.
    Video
  • MunsterTech
    • Sep 2014
    • 385
    Re: Canon IR 4235 42XX help to identify noise from machine
    check the life of the fuser, only noise ive seen on these models is the fuser main going
    • maxcopiers
      • Dec 2019
      • 15
      The fuser was replaced with one from another machine, but the noise happens still.
      The inner finisher D1 was disconnected, but the noise still happens.
      • maxcopiers
        • Dec 2019
        • 15
        The problem turned out to be a bad clutch. The clutch was replaced and the sound is now gone.
