Canon image press c1+ printing problem
  • burak
    • Feb 2019
    • 38
    Hello,
    Canon c1 has print problem like picture
    the same problem occurs for all colors.
  • GIUBOSS
    • 1385
    Re: Canon image press c1+ printing problem
    seems to be a problem with the black drum unit section, have you already checked it out?
    • GIUBOSS
      • 1385
      so you tried to print tests with individual colors
      • Andyboachie
        • 185
        Originally posted by burak
        Hello,
        I ask for your help [ATTACH=CONFIG]45353[/ATTACH]
        I would suggest you check the condition of laser and pre exposure.
        • burak
          • Feb 2019
          • 38
          Thanks for your help.
          But I noticed that 2 gears were broken in the development drive assembly.
          Could your problem be here?
          • Robert Silva
            • Jan 2019
            • 35
            Hello. Did you remove this developer unit assembly from behind the machine? Or did you conclude this by checking inside the machine? Does the machine have noise? How is the PG 10 sample? Does the individual color test have the same defect range?
