Canon C255 Image issues
  • tbsl
    • Oct 2014
    • 16
    Hi
    We have had an ongoing issue which we have been unable to solve.(see attached pics). Originally we thought it was the laser so we changed the laser, no change. On canons advice we change the main drive unit but no difference to the image.
    Machine boots up ok. No error or alarm codes but machine not setting up laser correctly. Vertical scan can be adjusted ok but horizontal scan can not be adjusted, makes no difference. So theres a magenta line I cannot get rid of.PG test page 6
    Any ideas?
    TIA
    John
  • GIUBOSS
    • 1443
    Re: Canon C255 Image issues
    main drive ?? Why didn't you think about the magenta drum unit, for example, as we talk about this?
    • tbsl
      • Oct 2014
      • 16
      Thanks for your response. We have changed the drum and swapped the following parts from a donor machine:-
      Main controller, ITB ,DC controller, HVT high and low voltage
      Bit stumped with this one
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Why would you think the problem would be a board.
        Regards Mark
          • 22784
          Hi
          Any ideas? TIA John
          Hey John,
          are the samples in LEF or SEF feed?
          jpg's really don't give us a good view of it. uploading samples in PDF format is much preferred.
          +1 on mga's advise... not likely related to a board
          did you run the alignment process?
          can you measure the distance between marks? compare to defect ruler in SM to find which part is culprit.
          you didn't swap the developer unit(s)?
          • onlyinnewfoundland
            • Apr 2013
            • 235
            Hi
            Any ideas?
            TIA
            John
            If you go under settings/reg > management settings > there is a spot to initialize all data. Try that. I have had a few new 3rd gen adv do weird stuff out of box.
            Does auto correct color mismatch work?
            • Andyboachie
              • 185
              Was it the whole drum unit you changed or just the cylinder? Have you thoroughly cleaned: scanner mirrors, laser mirrors and ATR sensors?
              Just as has been said, you are going too far with replacing HVT, DC Controller and ITB. You are not having a blank or even a fading copy.
              • Copylady72
                • Jul 2019
                • 35
                Have you cleaned the registration patch sensors?
                Sent from my SM-N950U using Tapatalk
                • tbsl
                  • Oct 2014
                  • 16
                  thanks for all the replies. Due to the corona virus issue another engineer took this job on and replaced the DC controller and it fixed the issue. Not sure how/why but at least it's fixed
                  • MunsterTech
                    • Sep 2014
                    • 385
                    hi,
                    in the previous thread, you said you had already replaced the DC controller, now another engineer replaced the DC again? Dont understand that
                    • Canuck
                      Tech Specialist
                      • 1715
                      Dcon..had this before. Sometimes a Dcon clear will fix it but sometimes it's the board(cleared after replacement I hope).
