Canon ir5045 paper jams and wrinkles in fuser unit showing error ps39
  • Japhet
    • Apr 2020
    • 3
    [Jamming] Canon ir5045 paper jams and wrinkles in fuser unit showing error ps39
    How do I resolve this paper jam in the fuser unit. The paper wrinkle as well. My check in service mode shows jam code ps39. please I need help
    Re: Canon ir5045 paper jams and wrinkles in fuser unit showing error ps39
    pull fuser check for:
    toner buildup on inlet plate.
    check for proper sensor movement
    check gearing for proper movement
    we also need to know:
    Total pages passed thru unit
    Total pages on PM parts
    Did a certified Tech preform PM's?
    Is it clean in the unit?
    Your User's Guide should show you how to acquire the info needed.
    If you have no user guide, one can be obtained free of charge by searching the InterNet. IF you cannot find one ask, and you could receive one. ( sorry just got done watching Adam-12 )
    • Japhet
      • Apr 2020
      • 3
      Thanks for your reply. But where is the ps39 sensor and how do I check the movement. Any image for me to locate it.
        Look in service manual
        • hidius
          • Jun 2015
          • 128
          ps39 is the reverse sensor. sometimes the sensor arm will pop of its holder. the way to check and fix is to remove the delivery unit then you can access it from the top
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            +1 easy to remove but if you are not sure you will need the service manual the delivery unit is the section above the fuser assy it's the top right door it can come out as one assy please unplug machine from mains when disconnecting and reconnecting the delivery unit
            Regards Mark
            • Andyboachie
              • 185
              Hi,
              You seem to be moving away from all the problem you defined.
              As far as I recall, you mentioned that the paper is creasing alongside a jam. This does not make it just a sensor problem. It has to do with the obstruction of the smooth movement of the paper through the fuser unit. I'm sure that a replacement of the fuser unit will solve the problem. If that happens, then there is sure to be either:
              1. a slip on the pathway through the fuser (caused by toner or dust).
              2. a wear in some bushings that has opened up the pathway
              3. a slight dislocation of a roller or weakening gear
              4. a need for replacement of any of the press roller or the heating roller
              Any one of the above will delay the movement of the paper towards ps39 to trigger a jam.
              • Canuck
                Tech Specialist
                • 1713
                Originally posted by Andyboachie
                Hi,
                Probably means folding up. If that sensor is not triggered, the delivery rolls don't begin to rotate and the paper will fold up. I've seen this delivery actuator issue on tons of Canons over the years. I put a piece of mylar over top of it so it won't pop out.
                • Andyboachie
                  • 185
                  That is true as well. A delay in the timing of when the paper is to get to that positional sensor will cause it to jam.
                  • Japhet
                    • Apr 2020
                    • 3
                    Thanks so much. I will try all suggestions. Hope it will fix it
                    • techandtrader
                      • Jun 2016
                      • 335
                      If Ps39 has popped out the machine will stillwork single sided. Not 2 sided.
                      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
