Ir advc 5235 missing yellow color
  • smiley
    • Aug 2008
    • 615
    Good day guys. This machine sometimes lost yellow color. Sometimes its fine. I already check the laser shutter motor. Transfer primary transfer roller and swap drum unit.and developing unit. I cant see any visible problem. Anyone can suggest a fix are greatly appreciated.thanks. and stay safe guys.
    there is no glory without sacrifice
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Ir advc 5235 missing yellow color
    Would be helpful if pdf sample was shown but it sounds like plastic drive coupling
    Regards Mark
    • smiley
      • Aug 2008
      • 615
      You mean the one that drives the dev. Unit? I will post the sample picture if i'll be back at costumers office.the yellow totaly gone. Even i try to print on single color yellow 0% appear but sometimes it goes back.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Yes FC8-4170-000
        Regards Mark
        • smiley
          • Aug 2008
          • 615
          Is it the one connect with the developing unit or with the machine?
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Its on the back of the machine look behind drums on rear frame you will see 8 drive couplings 4 x silver and 4x white
            Regards Mark
            • tsbservice
              Field tech
              • 7989
              Smiley of course it's in the machine side. Remember you swaped developer units.
              Sometimes it will drive, sometimes not, at the end drive will fail ultimately. Not seen in Canon, but I guess they are all the same.
              • smiley
                • Aug 2008
                • 615
                Thank you all guys i will check does plastic drive coupling and update you if problem fixed.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  No problem please keep us posted
                  Regards Mark
                  • Canuck
                    Tech Specialist
                    • 1713
                    If the dev couplings are good(machine and housing), check the drum dev drive assembly. The bushing gets oval shaped and you lose color intermittently. Sometimes logs E24 if I remember...pain in the butt to change this assembly color off.pdf
                    • doktor
                      • 214
                      In my same case the protective flap on the laser did not open. Check it out.
                      • smiley
                        • Aug 2008
                        • 615
                        How do you know if the flap does not open?
                        • smiley
                          • Aug 2008
                          • 615
                          Good day guy i went to client today. Check the laser shutter i try do remove it so that it will totaly open but still yellow color didnot appear. I try single color to check if the drum and developer rotate i swap the drum with one who have dots and i appears it means that the drum and developer rotate. Icheck those coupling at they look good and they rotate without any grinding noise or sound. So im thinking maybe the issue is on the laser unit. I will try to swap it next time and update you guys on the result.
                          • Canuck
                            Tech Specialist
                            • 1713
                            Definitely...Swap the black/cyan laser unit with the yellow/magenta...same laser assemblies. If deletion changes to black or cyan, it's the laser
                            • smiley
                              • Aug 2008
                              • 615
                              Thanks canuck i will try it and update the result.
