Ir advc 5235 missing yellow color
  • Andyboachie
    • 185
    #16
    Re: Ir advc 5235 missing yellow color
    Originally posted by smiley
    Thank you all guys i will check does plastic drive coupling and update you if problem fixed.
    Hello,
    Apart from the above suggestions, expect that any cause of disengagement between the yellow drum unit and its dev unit will give a blank yellow copy. I uphold my suspicion of the drum/dev unit so long as it occasionally comes out good. If you have already tried replacing both drum unit and dev unit with working ones and seen the results, try replacing the whole drum/dev unit assembly with a working one.
    We hope you get round it!
    • techandtrader
      • Jun 2016
      • 330
      #17
      You need to remember that Canon fixed the Dev Units with the new style Pin Coupler late C5o51 production and ALL C5200 have the updated Pin Coupler. Cant rule out a tech swap that you don't know about...IDK about compatibility either. This is a failed laser.
      I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
      • smiley
        • Aug 2008
        • 615
        #18
        For update guys today i replace the laser unit and it solve the problem thank you all guys. Stay safe.
        there is no glory without sacrifice
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          Thank you for update.
          Regards Mark
