firmware
  • patrickdaud25
    • Apr 2020
    • 3
    firmware
    need firmware for canon ir 3300 and other
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: firmware
    For a canon it's called system software you will also need the service support tool to load onto hdd {note it must be a Hdd designed for this machine cant use any hdd} also the problem you have got is the machine is very very VERY old and I don't think the system software is still available on Canon sims but I will check. But you may be able to get one from ebay of a old ir3300/2800/2200 with will have software preloaded.
    Regards Mark
    • copier tech
      • 8142
      Re: firmware
      Do you have an E602 error?
      Try booting up in repair mode.
      Shutdown & power back on keep holding down keys 1&9 leave it rebuilding can take over an hour.
      Turn off when "Download Standby" is shown.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Re: firmware
        Yes you still can get system software but you have to be a credited Canon engineer. But you could try the second reply on this thread he may be able to help good luck
        Regards Mark
