IR2318 print quality
  • uclbph
    • Jul 2011
    • 34
    [CQ] IR2318 print quality
    I have Canon IR2318. The printed paper background is not white. Tonner applied to the whole page and the background looks gray. attached here sample image.
    I have changed new drum and DC blade also.
    Kindly advice.
    Re: IR2318 print quality
    Kindly advice.
    uclbph[ATTACH=CONFIG]45579[/ATTACH]
    developer unit needs replacing
    • uclbph
      • Jul 2011
      • 34
      Drum unit or Toner Developing Unit ?
        you said you changed the drum and cleaning blade...
        were they NEW OEM?
        if yes.. change developer..
        how many clicks on the machine
        • uclbph
          • Jul 2011
          • 34
          were they NEW OEM?
          227k copy counter.
          Drum & DC blade New OEM installed.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            227k copy counter.
            If you fitted a drum and dcb. It will not be oem as they come as a drum unit try fitting a oem drum unit note non oem parts ie made in China are rubbish buy cheap pay twice.
            Regards Mark
            • tsbservice
              Field tech
              • 8000
              It's easy.
              Do you have background before replacement of drum and drum cleaning blade?
              1. No
              Trash the cheep Chinese garbage. Fit new OEM parts. Do adjustments as per Service manual.
              2. Yes
              Change the developer. Do adjustments as per Service manual.
